Toshiba Satellite P55W-C5316 Fan Replacement
  1. Toshiba Satellite P55W-C5316 Fan Replacement, Back Panel: step 1, image 1 of 2 Toshiba Satellite P55W-C5316 Fan Replacement, Back Panel: step 1, image 2 of 2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Fan Replacement: step 2, image 1 of 3 Toshiba Satellite P55W-C5316 Fan Replacement: step 2, image 2 of 3 Toshiba Satellite P55W-C5316 Fan Replacement: step 2, image 3 of 3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 Fan Replacement, Fan: step 3, image 1 of 1
    • Remove both screws from the fan.
  4. Toshiba Satellite P55W-C5316 Fan Replacement: step 4, image 1 of 2 Toshiba Satellite P55W-C5316 Fan Replacement: step 4, image 2 of 2
    • Remove the screws securing the 4 corners of the heatsink.
    • Gently remove the heatsink. Keep in mind thermal paste is used and it may be slightly difficult to remove.
  5. Toshiba Satellite P55W-C5316 Fan Replacement: step 5, image 1 of 3 Toshiba Satellite P55W-C5316 Fan Replacement: step 5, image 2 of 3 Toshiba Satellite P55W-C5316 Fan Replacement: step 5, image 3 of 3
    • Remove the small, beige colored connector securing the fan to the laptop and remove the fan and heatsink assembly from the laptop.
Zeyad Ali
349 Reputation
2 Guides authored
IUPUI, Team S2-G1, Harley Fall 2019 Member of IUPUI, Team S2-G1, Harley Fall 2019
IUPUI-HARLEY-F19S2G1
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 16
All Time: 387
