Toshiba Satellite P55W-C5316 Back Panel Replacement
  1. Toshiba Satellite P55W-C5316 Back Panel Replacement, Back Panel: step 1, image 1 of 2 Toshiba Satellite P55W-C5316 Back Panel Replacement, Back Panel: step 1, image 2 of 2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Back Panel Replacement: step 2, image 1 of 3 Toshiba Satellite P55W-C5316 Back Panel Replacement: step 2, image 2 of 3 Toshiba Satellite P55W-C5316 Back Panel Replacement: step 2, image 3 of 3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
Nicholas Caswell
117 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 950
