Toshiba Satellite P55-A5312 Battery Replacement
  1. Toshiba Satellite P55-A5312 Battery Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite P55-A5312 Battery Replacement, Battery: step 1, image 2 of 2
  2. Toshiba Satellite P55-A5312 Battery Replacement: step 2, image 1 of 2 Toshiba Satellite P55-A5312 Battery Replacement: step 2, image 2 of 2
    • Locate the battery, which is in the top right hand corner of the laptop.
    • Remove all the 2.5x6mm screws that secure the battery with a Philips 00 screwdriver.
  3. Toshiba Satellite P55-A5312 Battery Replacement: step 3, image 1 of 1
    • Locate the intersection of the wires that connect the battery to the motherboard.
    • Unplug these wires by gently pulling on the white plug, as shown in the picture.
  4. Toshiba Satellite P55-A5312 Battery Replacement: step 4, image 1 of 1
    • Carefully remove the speaker that is placed above the battery by gently pulling upward from one end. Be careful not to break a wire.
    • Move the speaker elsewhere while replacing the battery (do not disconnect it).
  5. Toshiba Satellite P55-A5312 Battery Replacement: step 5, image 1 of 1
    • Remove the battery from the laptop after it has been completely disconnected.
5 other people completed this guide.
ohatae
294 Reputation
2 Guides authored
Cal Poly, Team 9-1, Banghart Winter 2017 Member of Cal Poly, Team 9-1, Banghart Winter 2017
CPSU-BANGHART-W17S9G1
3 Members
6 Guides authored
One Comment
The repair guide was great. Got right through the battery change procedure. only took about 25 minutes start to finish. I was told by a friend to try this as a way to bypass the forgotten password at startup of the computer so that I could put a new password in it. The result is that did not work. Can anybody tell me how to do this
Roy Conrad - Reply
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 24
All Time: 5,825
