Toshiba Satellite P205D-S8804 Screen Replacement
  1. Toshiba Satellite P205D-S8804 Screen Replacement, Screen: step 1, image 1 of 1
    • With the screen on a flat surface, remove the screws in each corner of the screen. There will be 4 in total.
    • Note: The screws for the screen may be hidden under rubber pad at the top of the screen so they will have to be removed.
  2. Toshiba Satellite P205D-S8804 Screen Replacement: step 2, image 1 of 1
    • Using a metal spudger wedge open the front and back cover of the screen.
    • Take care to not damage the camera in the process.
  3. Toshiba Satellite P205D-S8804 Screen Replacement: step 3, image 1 of 2 Toshiba Satellite P205D-S8804 Screen Replacement: step 3, image 2 of 2
    • After the front cover is removed remove the two screws at the very bottom of the screen.
    • This will give you access to the screws running along the side of the screen.
  4. Toshiba Satellite P205D-S8804 Screen Replacement: step 4, image 1 of 1
    • Remove the four screws on the each side of the screen. There will be eight in total.
    • We recommend starting from the bottom and working upward.
  5. Toshiba Satellite P205D-S8804 Screen Replacement: step 5, image 1 of 1
    • Lay the screen flat on the keyboard so they the back panel can be accessed.
    • Remove all the tape on the video cable that connects the screen to the computer.
  6. Toshiba Satellite P205D-S8804 Screen Replacement: step 6, image 1 of 1
    • Remove the video cable from the screen.
    • After the video cable is removed the screen is free and can be removed from the computer.
Caroline Camp
1 Reputation
3 Guides authored
Baylor, Team 3-2, Whitney Spring 2017 Member of Baylor, Team 3-2, Whitney Spring 2017
BU-WHITNEY-S17S3G2
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 88
