Toshiba Satellite M55-S135 Keyboard Replacement
  1. Toshiba Satellite M55-S135 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Start with the laptop open and the keyboard facing you.
    • Tilt the screen away from you to reduce the risk of damaging it as you remove the keyboard.
  2. Toshiba Satellite M55-S135 Keyboard Replacement: step 2, image 1 of 2 Toshiba Satellite M55-S135 Keyboard Replacement: step 2, image 2 of 2
    • Locate the vertical seam between the speakers and the top row of keys on the keyboard.
    • Insert the tip of a nylon spudger into the seam and slowly pry up the panel.
    • Be sure to gently pry the panel to avoid damaging it or the laptop.
  3. Toshiba Satellite M55-S135 Keyboard Replacement: step 3, image 1 of 2 Toshiba Satellite M55-S135 Keyboard Replacement: step 3, image 2 of 2
    • Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips #00 screwdriver.
  4. Toshiba Satellite M55-S135 Keyboard Replacement: step 4, image 1 of 1
    • Use the nylon spudger to pry up the keyboard. Start with one side and then the other.
    • Be sure to pry gently with the screwdriver to avoid damaging the keyboard and keys.
  5. Toshiba Satellite M55-S135 Keyboard Replacement: step 5, image 1 of 1
    • Gently lift the keyboard to reveal the keyboard cable located near the mouse pad.
    • Disconnect the keyboard cable.
    • Be sure to disconnect the cable before removing the keyboard to avoid damaging it.
klismann Evora
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 706
