Toshiba Satellite M305D-S4829 Keyboard Replacement
  1. Toshiba Satellite M305D-S4829 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 Keyboard Replacement: step 2, image 1 of 1
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 Keyboard Replacement, Keyboard: step 3, image 1 of 1
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 Keyboard Replacement: step 4, image 1 of 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: step 4, image 2 of 2
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Toshiba Satellite M305D-S4829 Keyboard Replacement: step 5, image 1 of 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: step 5, image 2 of 2
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Toshiba Satellite M305D-S4829 Keyboard Replacement: step 6, image 1 of 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: step 6, image 2 of 2
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Toshiba Satellite M305D-S4829 Keyboard Replacement: step 7, image 1 of 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: step 7, image 2 of 2
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Toshiba Satellite M305D-S4829 Keyboard Replacement: step 8, image 1 of 1
    • Your keyboard has now been successfully removed.
2 other people completed this guide.
Michael Jensen
425 Reputation
6 Guides authored
Cal Poly, Team 4-3, Regan Spring 2011 Member of Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 4,561
