Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement
  1. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement, Battery: step 1, image 1 of 1
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: step 2, image 1 of 1
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement, CD/DVD Drive: step 3, image 1 of 1
    • Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: step 4, image 1 of 2 Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: step 4, image 2 of 2
    • Locate and remove the circled screw with a Phillips #0 screwdriver.
  5. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: step 5, image 1 of 1
    • Use the plastic opening tool to pry the CD/DVD drive out of the frame.
  6. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: step 6, image 1 of 1
    • Gently remove the CD/DVD drive from the laptop body.
Michael Jensen
425 Reputation
6 Guides authored
Cal Poly, Team 4-3, Regan Spring 2011 Member of Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 3,077
