Toshiba Satellite L675D-S7016 Screen Replacement
  1. Toshiba Satellite L675D-S7016 Screen Replacement, Battery: step 1, image 1 of 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Screen Replacement: step 2, image 1 of 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Screen Replacement: step 3, image 1 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 3, image 2 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 3, image 3 of 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Screen Replacement, Back Panel Removal: step 4, image 1 of 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 Screen Replacement: step 5, image 1 of 2 Toshiba Satellite L675D-S7016 Screen Replacement: step 5, image 2 of 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 Screen Replacement, Hard Drive: step 6, image 1 of 2 Toshiba Satellite L675D-S7016 Screen Replacement, Hard Drive: step 6, image 2 of 2
    • Slide the hard drive to the left, using the silver tab.
    • Pull up the silver tab, removing the hard drive from the slot.
    • Do not touch the metal data pins on the hard drive or computer.
  7. Toshiba Satellite L675D-S7016 Screen Replacement, RAM: step 7, image 1 of 3 Toshiba Satellite L675D-S7016 Screen Replacement, RAM: step 7, image 2 of 3 Toshiba Satellite L675D-S7016 Screen Replacement, RAM: step 7, image 3 of 3
    • Using your fingers, spread the spring tabs holding the top stick of RAM in place.
    • Once the tabs are spread apart, the stick of RAM will pop up.
    • Remove the first stick of RAM by pulling out along the same angle the RAM stick springs up.
  8. Toshiba Satellite L675D-S7016 Screen Replacement: step 8, image 1 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 8, image 2 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 8, image 3 of 3
    • Repeat the same procedure to remove the second stick of RAM.
  9. Toshiba Satellite L675D-S7016 Screen Replacement, Keyboard: step 9, image 1 of 3 Toshiba Satellite L675D-S7016 Screen Replacement, Keyboard: step 9, image 2 of 3 Toshiba Satellite L675D-S7016 Screen Replacement, Keyboard: step 9, image 3 of 3
    • Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
    • Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
  10. Toshiba Satellite L675D-S7016 Screen Replacement: step 10, image 1 of 2 Toshiba Satellite L675D-S7016 Screen Replacement: step 10, image 2 of 2
    • Remove the first 3mm screw with the Phillips #1 screwdriver.
    • Remove the next three 3mm screws.
  11. Toshiba Satellite L675D-S7016 Screen Replacement: step 11, image 1 of 2 Toshiba Satellite L675D-S7016 Screen Replacement: step 11, image 2 of 2
    • Lift the keyboard gently . Slide it forward towards the screen and speakers. This reveals the connection needed for the next step.
  12. Toshiba Satellite L675D-S7016 Screen Replacement: step 12, image 1 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 12, image 2 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 12, image 3 of 3
    • Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
    • Carefully slide the connector out of the port.
  13. Toshiba Satellite L675D-S7016 Screen Replacement, Top Case Housing: step 13, image 1 of 1
    • Remove the following screws with a Phillips #1 screwdriver.
    • Seventeen 5mm screws (recessed)
    • Three 2mm screws in the battery bay (flush-mounted)
    • Single 5mm screw does not need removal unless working on the screen
  14. Toshiba Satellite L675D-S7016 Screen Replacement: step 14, image 1 of 2 Toshiba Satellite L675D-S7016 Screen Replacement: step 14, image 2 of 2
    • Remove five 5mm screws with the screwdriver.
  15. Toshiba Satellite L675D-S7016 Screen Replacement: step 15, image 1 of 2 Toshiba Satellite L675D-S7016 Screen Replacement: step 15, image 2 of 2
    • Locate the trackpad connector.
    • Pull the ribbon from the connector.
  16. Toshiba Satellite L675D-S7016 Screen Replacement: step 16, image 1 of 2 Toshiba Satellite L675D-S7016 Screen Replacement: step 16, image 2 of 2
    • Pry under the top case housing along the perimeter with a plastic opening tool.
    • Be careful and gentle with this step, the clips you are releasing here are plastic and can be broken by violent prying.
  17. Toshiba Satellite L675D-S7016 Screen Replacement, Screen: step 17, image 1 of 3 Toshiba Satellite L675D-S7016 Screen Replacement, Screen: step 17, image 2 of 3 Toshiba Satellite L675D-S7016 Screen Replacement, Screen: step 17, image 3 of 3
    • Remove the screen input wire from the port.
  18. Toshiba Satellite L675D-S7016 Screen Replacement: step 18, image 1 of 2 Toshiba Satellite L675D-S7016 Screen Replacement: step 18, image 2 of 2
    • Slide the metal power button connector out of its port, allowing the black wire to be moved from under it.
  19. Toshiba Satellite L675D-S7016 Screen Replacement: step 19, image 1 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 19, image 2 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 19, image 3 of 3
    Tool used on this step:
    Buy
    • Lift the black connector with tweezers and repeat the same action for the white connector.
  20. Toshiba Satellite L675D-S7016 Screen Replacement: step 20, image 1 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 20, image 2 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 20, image 3 of 3
    • The screen is attached with two hinges on both sides of the laptop.
    • Remove the three 5mm screws (two on the left hinge, one on the right hinge) using a screwdriver.
    • Remove brass fitting held in place by removing the 5mm screw circled in yellow in step 15.
  21. Toshiba Satellite L675D-S7016 Screen Replacement: step 21, image 1 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 21, image 2 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 21, image 3 of 3
    • Remove the 6 rubber tabs on the housing using a metal Spudger.
    • Remove the six 6mm screws holding the housing.
  22. Toshiba Satellite L675D-S7016 Screen Replacement: step 22, image 1 of 2 Toshiba Satellite L675D-S7016 Screen Replacement: step 22, image 2 of 2
    • Use the plastic opening tool to pry the screen housing.
    • Only pry from the outside edges! Prying from the inside edges will likely damage the LCD panel.
  23. Toshiba Satellite L675D-S7016 Screen Replacement: step 23, image 1 of 2 Toshiba Satellite L675D-S7016 Screen Replacement: step 23, image 2 of 2
    • Remove two 5mm screws using a screwdriver. There is one screw at each hinge.
    • Remove white wire from the perimeter of the plastic housing.
  24. Toshiba Satellite L675D-S7016 Screen Replacement: step 24, image 1 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 24, image 2 of 3 Toshiba Satellite L675D-S7016 Screen Replacement: step 24, image 3 of 3
    • Disconnect the webcam data wire using tweezers.
  25. Toshiba Satellite L675D-S7016 Screen Replacement: step 25, image 1 of 2 Toshiba Satellite L675D-S7016 Screen Replacement: step 25, image 2 of 2
    • Remove the three 2.5mm screws on each side of the screen casing with a screwdriver.
    • The two metal casings can now be removed.
2 other people completed this guide.
Austin Bons
1,131 Reputation
8 Guides authored
UC Davis, Team 2-2, Oliver Fall 2016 Member of UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,206
