Toshiba Satellite L675D-S7016 Keyboard Replacement
  1. Toshiba Satellite L675D-S7016 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Keyboard Replacement: step 2, image 1 of 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Keyboard Replacement: step 3, image 1 of 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: step 3, image 2 of 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: step 3, image 3 of 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: step 4, image 1 of 3 Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: step 4, image 2 of 3 Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: step 4, image 3 of 3
    • Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
    • Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
  5. Toshiba Satellite L675D-S7016 Keyboard Replacement: step 5, image 1 of 2 Toshiba Satellite L675D-S7016 Keyboard Replacement: step 5, image 2 of 2
    • Remove the first 3mm screw with the Phillips #1 screwdriver.
    • Remove the next three 3mm screws.
  6. Toshiba Satellite L675D-S7016 Keyboard Replacement: step 6, image 1 of 2 Toshiba Satellite L675D-S7016 Keyboard Replacement: step 6, image 2 of 2
    • Lift the keyboard gently . Slide it forward towards the screen and speakers. This reveals the connection needed for the next step.
  7. Toshiba Satellite L675D-S7016 Keyboard Replacement: step 7, image 1 of 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: step 7, image 2 of 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: step 7, image 3 of 3
    • Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
    • Carefully slide the connector out of the port.
Austin Bons
1,131 Reputation
8 Guides authored
UC Davis, Team 2-2, Oliver Fall 2016 Member of UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 11
All Time: 783
