Toshiba Satellite L675D-S7016 Hard Drive Replacement
  1. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Hard Drive Replacement: step 2, image 1 of 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Hard Drive Replacement: step 3, image 1 of 3 Toshiba Satellite L675D-S7016 Hard Drive Replacement: step 3, image 2 of 3 Toshiba Satellite L675D-S7016 Hard Drive Replacement: step 3, image 3 of 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Back Panel Removal: step 4, image 1 of 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 Hard Drive Replacement: step 5, image 1 of 2 Toshiba Satellite L675D-S7016 Hard Drive Replacement: step 5, image 2 of 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Hard Drive: step 6, image 1 of 2 Toshiba Satellite L675D-S7016 Hard Drive Replacement, Hard Drive: step 6, image 2 of 2
    • Slide the hard drive to the left, using the silver tab.
    • Pull up the silver tab, removing the hard drive from the slot.
    • Do not touch the metal data pins on the hard drive or computer.
To install a new Hard Drive, follow these instructions in reverse order.
2 other people completed this guide.
Austin Bons
1,131 Reputation
8 Guides authored
UC Davis, Team 2-2, Oliver Fall 2016 Member of UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,028
