Toshiba Satellite L655D-S5095 Screen Replacement
  1. Toshiba Satellite L655D-S5095 Screen Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite L655D-S5095 Screen Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite L655D-S5095 Screen Replacement, Battery: step 1, image 3 of 3
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 Screen Replacement: step 2, image 1 of 1
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 Screen Replacement, Keyboard: step 3, image 1 of 1
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 Screen Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 Screen Replacement: step 5, image 1 of 2 Toshiba Satellite L655D-S5095 Screen Replacement: step 5, image 2 of 2
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 Screen Replacement: step 6, image 1 of 1
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 Screen Replacement: step 7, image 1 of 1
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
  8. Toshiba Satellite L655D-S5095 Screen Replacement, Screen: step 8, image 1 of 2 Toshiba Satellite L655D-S5095 Screen Replacement, Screen: step 8, image 2 of 2
    • Remove stickers from four corners of laptop.
    • Remove screws underneath stickers.
  9. Toshiba Satellite L655D-S5095 Screen Replacement: step 9, image 1 of 2 Toshiba Satellite L655D-S5095 Screen Replacement: step 9, image 2 of 2
    • Use plastic opening tool to pry the hinges off.
    • Remove the screen cover.
    • Unscrew the six screws on the bottom of the screen near the top of the hinges.
  10. Toshiba Satellite L655D-S5095 Screen Replacement: step 10, image 1 of 2 Toshiba Satellite L655D-S5095 Screen Replacement: step 10, image 2 of 2
    • Remove cable located next to the fan.
    • Fold down screen without screen back cover to remove cable as shown.
  11. Toshiba Satellite L655D-S5095 Screen Replacement: step 11, image 1 of 2 Toshiba Satellite L655D-S5095 Screen Replacement: step 11, image 2 of 2
    • Unscrew both screws on each side of the screen.
    • Remove the screen.
2 other people completed this guide.
Christopher Camara
194 Reputation
1 Guide authored
One Comment
Que éxito esta pagina , muy gran trabajo, soy de Perú y creo que este tipo de trabajos son muy bien valorados, saludos a la distancia.
Korregan - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 27
All Time: 2,255
