Toshiba Satellite L655D-S5095 RAM Replacement
  1. Toshiba Satellite L655D-S5095 RAM Replacement, RAM: step 1, image 1 of 2 Toshiba Satellite L655D-S5095 RAM Replacement, RAM: step 1, image 2 of 2
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Toshiba Satellite L655D-S5095 RAM Replacement: step 2, image 1 of 1
    • Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Toshiba Satellite L655D-S5095 RAM Replacement: step 3, image 1 of 3 Toshiba Satellite L655D-S5095 RAM Replacement: step 3, image 2 of 3 Toshiba Satellite L655D-S5095 RAM Replacement: step 3, image 3 of 3
    • Push the two tabs outwards, away from the RAM. The RAM should spring up.
  4. Toshiba Satellite L655D-S5095 RAM Replacement: step 4, image 1 of 3 Toshiba Satellite L655D-S5095 RAM Replacement: step 4, image 2 of 3 Toshiba Satellite L655D-S5095 RAM Replacement: step 4, image 3 of 3
    • Pull the top RAM stick out gently.
    • Repeat steps 3 and 4 for the bottom RAM stick.
    • When installing the new RAM, line up the notches in the RAM's contacts and insert it at the same angle you removed it.
8 other people completed this guide.
Jerry Wakai
377 Reputation
4 Guides authored
Cal Poly, Team 7-7, Maness Winter 2013 Member of Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Members
6 Guides authored
2 Comments
Thank-You! So Much!
Sandra Crockett - Reply
Awesome & Simple! Thank-you! My Model is a Satellite P105-S6147 1GBX2 DDR2-666 Sodimm 2BG Total.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 3,679
