Toshiba Satellite L655D-S5095 Hard Drive Replacement
  1. Toshiba Satellite L655D-S5095 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Toshiba Satellite L655D-S5095 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Unscrew the two screws holding the panel over the hard drive using a Phillips screwdriver. The panel is located on the top right of the laptop's underside.
  2. Toshiba Satellite L655D-S5095 Hard Drive Replacement: step 2, image 1 of 1
    • Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Toshiba Satellite L655D-S5095 Hard Drive Replacement: step 3, image 1 of 2 Toshiba Satellite L655D-S5095 Hard Drive Replacement: step 3, image 2 of 2
    • Remove the screw located under the plastic tab.
  4. Toshiba Satellite L655D-S5095 Hard Drive Replacement: step 4, image 1 of 2 Toshiba Satellite L655D-S5095 Hard Drive Replacement: step 4, image 2 of 2
    • Remove the hard drive by pulling the tab upwards and sliding the hard drive out.
6 other people completed this guide.
Jerry Wakai
377 Reputation
4 Guides authored
Cal Poly, Team 7-7, Maness Winter 2013 Member of Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 24
All Time: 3,798
