Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement
  1. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: step 1, image 1 of 3 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: step 1, image 2 of 3 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: step 1, image 3 of 3
    • Using a plastic opening tool, remove the four plastic stickers located on the four corners of the LCD screen assembly. These plastic stickers are covering screws.
    • Use a Phillips #1 screwdriver to remove the now uncovered 5.75mm screws and place them to the side.
  2. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: step 2, image 1 of 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: step 2, image 2 of 2
    • With a plastic soft pry tool, open up the laptop display assembly by methodically prying from left to right. Be careful to not damage any internal circuitry.
    • Do not attempt to pry apart the bottom, the LCD assembly never gets fully disassembled in this tutorial.
  3. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: step 3, image 1 of 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: step 3, image 2 of 2
    • Remove the 2 pieces of black tape using a sharp tool to free the camera board, note that the camera board is still connected to a cable.
  4. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: step 4, image 1 of 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully disconnect the camera board from the laptop. We used tweezers.
Robby
52 Reputation
1 Guide authored
Cal Poly, Team 7-7, Maness Winter 2013 Member of Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 2,592
