Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement
  1. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: step 1, image 1 of 2 Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: step 1, image 2 of 2
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: step 2, image 1 of 1
    • Remove the panel, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: step 3, image 1 of 1
    • Unscrew the 3.9 mm screw located at the bottom right of the panel.
  4. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to pry the CD drive out of the casing.
  5. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: step 5, image 1 of 1
    • Once the CD drive is out far enough to grip, pull the CD drive out to the right.
Torey
210 Reputation
1 Guide authored
Cal Poly, Team 7-7, Maness Winter 2013 Member of Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 2,284
