Toshiba Satellite L55t-B5271 CD Drive Replacement
  1. Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: step 1, image 3 of 3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271  CD Drive Replacement: step 2, image 1 of 2 Toshiba Satellite L55t-B5271  CD Drive Replacement: step 2, image 2 of 2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271  CD Drive Replacement: step 3, image 1 of 3 Toshiba Satellite L55t-B5271  CD Drive Replacement: step 3, image 2 of 3 Toshiba Satellite L55t-B5271  CD Drive Replacement: step 3, image 3 of 3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: step 4, image 1 of 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: step 4, image 2 of 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: step 4, image 3 of 3
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271  CD Drive Replacement, CD Drive: step 5, image 1 of 2 Toshiba Satellite L55t-B5271  CD Drive Replacement, CD Drive: step 5, image 2 of 2
    • Remove the 3 mm Philips head screw that connects the CD drive to motherboard with a Phillips #00 screwdriver.
  6. Toshiba Satellite L55t-B5271  CD Drive Replacement: step 6, image 1 of 2 Toshiba Satellite L55t-B5271  CD Drive Replacement: step 6, image 2 of 2
    • Gently pull the CD drive out, disconnecting it from the motherboard connector marked in blue.
Garrett Garofalo
298 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 280
