Toshiba Satellite L55-A RAM Module Replacement
  1. Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM cover: step 1, image 1 of 1
    • Before you begin, be sure to power down your laptop.
    • Flip the laptop over so that the back cover is facing up.
    • Unscrew the captive Phillips screw securing the RAM cover.
  2. Toshiba Satellite L55-A RAM Module Replacement: step 2, image 1 of 2 Toshiba Satellite L55-A RAM Module Replacement: step 2, image 2 of 2
    • Lift up the edge of the RAM cover and remove it.
  3. Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: step 3, image 1 of 3 Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: step 3, image 2 of 3 Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: step 3, image 3 of 3
    • This step shows how to remove a RAM module.
    • Use your fingers to spread the two metal clips securing the edge of the RAM module. This should free the module and cause it to pop up slightly.
    • Pull the RAM module out of its slot and remove it.
  4. Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: step 4, image 1 of 3 Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: step 4, image 2 of 3 Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: step 4, image 3 of 3
    • This step shows how to insert a RAM module.
    • Insert the replacement RAM at a shallow angle into the RAM slot until the gold contacts are fully socketed.
    • Use your fingers to gently press the RAM module's edges down until both metal clips snap into place.
    • If your laptop will not properly recognize the installed RAM, unseat and reseat the RAM, making sure that all modules are fully locked in place.
Arthur Shi
254,555 Reputation
529 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,420 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 227
