Toshiba Satellite L455D-S5976 WIfi Card Replacement
  1. Toshiba Satellite L455D-S5976 WIfi Card Replacement, Wifi Card: step 1, image 1 of 1
    • Unscrew the Phillips #1 4mm screw from the middle panel using a Phillips #1 screwdriver.
  2. Toshiba Satellite L455D-S5976 WIfi Card Replacement: step 2, image 1 of 1
    • Remove the middle panel by lifting up and out.
  3. Toshiba Satellite L455D-S5976 WIfi Card Replacement: step 3, image 1 of 1
    • Remove the two Phillips #1 6mm screws from the wifi card using a Phillips #1 screwdriver.
  4. Toshiba Satellite L455D-S5976 WIfi Card Replacement: step 4, image 1 of 1
    • Unsnap the two cables from the wifi card.
  5. Toshiba Satellite L455D-S5976 WIfi Card Replacement: step 5, image 1 of 1
    • Remove the wifi card using your hands.
4 other people completed this guide.
NateJohnson
1,047 Reputation
5 Guides authored
Cal Poly, Team 9-26, Maness Winter 2014 Member of Cal Poly, Team 9-26, Maness Winter 2014
CPSU-MANESS-W14S9G26
4 Members
5 Guides authored
One Comment
Wonder if I did change the Wi-Fi card and it stil doesn't work
chrisww3297 - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 1,107
