Toshiba Satellite L455D-S5976 RAM Replacement
  1. Toshiba Satellite L455D-S5976 RAM Replacement, RAM: step 1, image 1 of 1
    • Unscrew the 4mm screw from the middle panel using a Phillips #1.
  2. Toshiba Satellite L455D-S5976 RAM Replacement: step 2, image 1 of 1
    • Lift up on the middle panel and remove it.
  3. Toshiba Satellite L455D-S5976 RAM Replacement: step 3, image 1 of 1
    • Pull the right clip to the right and left clip to the left using your right and left hands respectively.
  4. Toshiba Satellite L455D-S5976 RAM Replacement: step 4, image 1 of 1
    • Once the clips have been removed, the RAM will pop up.
  5. Toshiba Satellite L455D-S5976 RAM Replacement: step 5, image 1 of 1
    • Slide the RAM out of its position and remove it.
4 other people completed this guide.
NateJohnson
1,047 Reputation
5 Guides authored
Cal Poly, Team 9-26, Maness Winter 2014 Member of Cal Poly, Team 9-26, Maness Winter 2014
CPSU-MANESS-W14S9G26
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,579
