Toshiba Satellite L455D-S5976 Optical Drive Replacement
  1. Toshiba Satellite L455D-S5976 Optical Drive Replacement, Battery: step 1, image 1 of 1
    • Unlock the right tab by sliding it to the right with your finger.
  2. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 2, image 1 of 1
    • Hold the left tab to the left using your left hand.
  3. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 3, image 1 of 1
    • Remove the battery by placing your finger in the middle groove and lifting up.
  4. Toshiba Satellite L455D-S5976 Optical Drive Replacement, Optical Drive: step 4, image 1 of 1
    • Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
  5. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 5, image 1 of 1
    • Remove the two Phillips #1 6mm screws from the backside of your computer using a Phillips #1 screwdriver.
  6. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 6, image 1 of 1
    • Remove the three 3mm screws from beneath the battery with a Phillips #1 screwdriver.
  7. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 7, image 1 of 1
    • Lift up the corner panel and remove it with your hand.
  8. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 8, image 1 of 1
    • Unscrew the four Phillips #1 3mm using a Phillips #1 screwdriver.
    • Unscrew the four 10mm screws around hard drive using a Phillips #1 screwdriver.
  9. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 9, image 1 of 2 Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 9, image 2 of 2
    • To remove the hard drive case, first pull the black tab to the right.
    • Then pull the black tab up to remove the case.
  10. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 10, image 1 of 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 10, image 2 of 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 10, image 3 of 3
    • Remove the plastic strip above the "F" keys using the spudger by placing the small end of the spudger under the strip and lifting up.
  11. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 11, image 1 of 1
    • Remove the two Phillips #1 3mm screws underneath the plastic strip using a Phillips #1 screwdriver.
  12. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 12, image 1 of 1
    • Lift the keyboard up and remove it with your hands.
  13. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 13, image 1 of 1
    • Remove the five Phillips #1 10mm screws underneath the keyboard using a Phillips #1 screwdriver.
  14. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 14, image 1 of 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 14, image 2 of 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 14, image 3 of 3
    • Lift up the plastic panel and carefully disconnect the red and white ports.
    • Remove the panel
  15. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 15, image 1 of 1
    • Turn the laptop over so the bottom is facing up
    • Then remove the 3mm screw with a #1 screwdriver, located underneath the panel containing the wifi card and RAM
  16. Toshiba Satellite L455D-S5976 Optical Drive Replacement: step 16, image 1 of 1
    • Turn the laptop back over so the motherboard is facing up
    • Now slide the optical drive out of the computer by gently pulling it to the right
2 other people completed this guide.
NateJohnson
1,047 Reputation
5 Guides authored
Cal Poly, Team 9-26, Maness Winter 2014 Member of Cal Poly, Team 9-26, Maness Winter 2014
CPSU-MANESS-W14S9G26
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,156
