Toshiba Satellite L455-S5975 WiFi Card Replacement
  1. Toshiba Satellite L455-S5975 WiFi Card Replacement, WiFi Card: step 1, image 1 of 1
    • Flip Laptop into an upside-down position.
    • Push latches (indicated in red) outward.
    • Lift battery by notch (indicated in green) to remove.
  2. Toshiba Satellite L455-S5975 WiFi Card Replacement: step 2, image 1 of 2 Toshiba Satellite L455-S5975 WiFi Card Replacement: step 2, image 2 of 2
    • Remove the plastic cover closest to the battery by first unscrewing the single 7mm screw (in red) with the phillips #00 screwdriver.
    • Now, lift the cover by the notch under the screw (in red) using a plastic opening tool.
  3. Toshiba Satellite L455-S5975 WiFi Card Replacement: step 3, image 1 of 3 Toshiba Satellite L455-S5975 WiFi Card Replacement: step 3, image 2 of 3 Toshiba Satellite L455-S5975 WiFi Card Replacement: step 3, image 3 of 3
    • Locate the Wifi Card on the right-hand side of compartment you just revealed
    • Remove the black and white wire by carefully pulling them off with the plastic lever (you will hear a light snapping sound).
  4. Toshiba Satellite L455-S5975 WiFi Card Replacement: step 4, image 1 of 1
    • Unscrew the two 6 mm screws (indicated in red) located at the bottom of the WiFi card and store them in a safe place.
  5. Toshiba Satellite L455-S5975 WiFi Card Replacement: step 5, image 1 of 2 Toshiba Satellite L455-S5975 WiFi Card Replacement: step 5, image 2 of 2
    • Gently remove the wifi card from the laptop.
Note: When installing new WiFi card be sure to connect the black wire to the right where there is a small letter “B” imprinted and place white on the opposite side.
2 other people completed this guide.
Dylan Baker
188 Reputation
1 Guide authored
UMD team 2 Member of UMD team 2
Community
4 Members
1 Guide authored
One Comment
are you aware of any compatible upgrades for a faster speed, like a dual band 5ghz card? from what im gathering its probably not worth the trial and error, because the antenna is designed probably for just 2.4ghz, so i'm thinking a usb dongle is the best option but wondering what your thoughts are? great guide btw
Tyler Bombara - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 2,260
