Toshiba Satellite L455-S5975 Keyboard Replacement
  1. Toshiba Satellite L455-S5975 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Toshiba Satellite L455-S5975 Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Toshiba Satellite L455-S5975 Keyboard Replacement: step 2, image 1 of 1
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Toshiba Satellite L455-S5975 Keyboard Replacement: step 3, image 1 of 1
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  4. Toshiba Satellite L455-S5975 Keyboard Replacement: step 4, image 1 of 2 Toshiba Satellite L455-S5975 Keyboard Replacement: step 4, image 2 of 2
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
Mike Kennedy
160 Reputation
4 Guides authored
Cal Poly, Team 2-21, Maness Spring 2013 Member of Cal Poly, Team 2-21, Maness Spring 2013
CPSU-MANESS-S13S2G21
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 2,377
