Toshiba Satellite L455-S5975 Hard Drive Replacement
  1. Toshiba Satellite L455-S5975 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Remove the two 7 mm screws with a Phillips#00 Screwdriver
  2. Toshiba Satellite L455-S5975 Hard Drive Replacement: step 2, image 1 of 1
    • Using a flat head from a plastic opening tool to lift open the cover.
  3. Toshiba Satellite L455-S5975 Hard Drive Replacement: step 3, image 1 of 1
    • Remove the four 6mm screws with the Phillips #00 screwdriver.
  4. Toshiba Satellite L455-S5975 Hard Drive Replacement: step 4, image 1 of 1
    • Pull out black tab located on the hard drive to slide it out.
Mike Kennedy
160 Reputation
4 Guides authored
Cal Poly, Team 2-21, Maness Spring 2013 Member of Cal Poly, Team 2-21, Maness Spring 2013
CPSU-MANESS-S13S2G21
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 3,443
