Toshiba Satellite L45-S7423 Wireless Card Replacement
  1. Toshiba Satellite L45-S7423 Wireless Card Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Battery: step 1, image 3 of 3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Wireless Card Replacement: step 2, image 1 of 2 Toshiba Satellite L45-S7423 Wireless Card Replacement: step 2, image 2 of 2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Wireless Card Replacement: step 3, image 1 of 2 Toshiba Satellite L45-S7423 Wireless Card Replacement: step 3, image 2 of 2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Wireless Card Replacement, Bottom Access Panel: step 4, image 1 of 3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Bottom Access Panel: step 4, image 2 of 3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Bottom Access Panel: step 4, image 3 of 3
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 Wireless Card Replacement: step 5, image 1 of 3 Toshiba Satellite L45-S7423 Wireless Card Replacement: step 5, image 2 of 3 Toshiba Satellite L45-S7423 Wireless Card Replacement: step 5, image 3 of 3
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 Wireless Card Replacement, Wireless Card: step 6, image 1 of 3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Wireless Card: step 6, image 2 of 3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Wireless Card: step 6, image 3 of 3
    • Remove the black and the white antenna wires attached to the wireless card.
    • Using a plastic removal tool, gently pop the connections apart.
  7. Toshiba Satellite L45-S7423 Wireless Card Replacement: step 7, image 1 of 2 Toshiba Satellite L45-S7423 Wireless Card Replacement: step 7, image 2 of 2
    • Remove the screws holding the wireless card in place.
    • Two 3.6 mm Phillips screws.
  8. Toshiba Satellite L45-S7423 Wireless Card Replacement: step 8, image 1 of 1
    • The wireless card will automatically pop up allowing for easy removal.
  9. Toshiba Satellite L45-S7423 Wireless Card Replacement: step 9, image 1 of 2 Toshiba Satellite L45-S7423 Wireless Card Replacement: step 9, image 2 of 2
    • Pull to remove the wireless card.
2 other people completed this guide.
Stephen Sippel
194 Reputation
9 Guides authored
Cal Poly, Team 21-54, Johann Spring 2013 Member of Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 2,230
