Introduction
The LCD display can be easily separated from the laptop body to allow for replacement if it is damaged or functioning improperly.
Make sure the battery lock switch is switched to the unlocked position.
The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Remove the Phillips screw holding the panel in place and then use a finger to remove the panel.
3 other people completed this guide.
