Toshiba Satellite L35-S2174 RAM Replacement
  1. Toshiba Satellite L35-S2174 RAM Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 RAM Replacement: step 2, image 1 of 2 Toshiba Satellite L35-S2174 RAM Replacement: step 2, image 2 of 2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 RAM Replacement: step 3, image 1 of 2 Toshiba Satellite L35-S2174 RAM Replacement: step 3, image 2 of 2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 RAM Replacement: step 4, image 1 of 1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 RAM Replacement, RAM: step 5, image 1 of 3 Toshiba Satellite L35-S2174 RAM Replacement, RAM: step 5, image 2 of 3 Toshiba Satellite L35-S2174 RAM Replacement, RAM: step 5, image 3 of 3
    • Unscrew the two circled screws with a J1 screwdriver. The screws will remain attached to the panel.
    • Lift the panel and remove it from the laptop.
  6. Toshiba Satellite L35-S2174 RAM Replacement: step 6, image 1 of 3 Toshiba Satellite L35-S2174 RAM Replacement: step 6, image 2 of 3 Toshiba Satellite L35-S2174 RAM Replacement: step 6, image 3 of 3
    • Pull the flaps apart on either side of the RAM chip. It will pop upwards.
    • Carefully lift the RAM chip out of the computer.
Fiona Turick
101 Reputation
1 Guide authored
UMass Dartmouth, Team 1-4, Catania Fall 2016 Member of UMass Dartmouth, Team 1-4, Catania Fall 2016
UMASSD-CATANIA-F16S1G4
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 10
All Time: 304
