Toshiba Satellite L305D-S5950 Speaker Replacement
  1. Toshiba Satellite L305D-S5950 Speaker Replacement, Battery: step 1, image 1 of 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Speaker Replacement: step 2, image 1 of 2 Toshiba Satellite L305D-S5950 Speaker Replacement: step 2, image 2 of 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Speaker Replacement: step 3, image 1 of 2 Toshiba Satellite L305D-S5950 Speaker Replacement: step 3, image 2 of 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Speaker Replacement: step 4, image 1 of 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Speaker Replacement, Keyboard: step 5, image 1 of 2 Toshiba Satellite L305D-S5950 Speaker Replacement, Keyboard: step 5, image 2 of 2
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 Speaker Replacement: step 6, image 1 of 1
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 Speaker Replacement: step 7, image 1 of 3 Toshiba Satellite L305D-S5950 Speaker Replacement: step 7, image 2 of 3 Toshiba Satellite L305D-S5950 Speaker Replacement: step 7, image 3 of 3
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 Speaker Replacement: step 8, image 1 of 1
    • Remove the keyboard completely from the laptop.
  9. Toshiba Satellite L305D-S5950 Speaker Replacement, Motherboard Cover: step 9, image 1 of 2 Toshiba Satellite L305D-S5950 Speaker Replacement, Motherboard Cover: step 9, image 2 of 2
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  10. Toshiba Satellite L305D-S5950 Speaker Replacement: step 10, image 1 of 3 Toshiba Satellite L305D-S5950 Speaker Replacement: step 10, image 2 of 3 Toshiba Satellite L305D-S5950 Speaker Replacement: step 10, image 3 of 3
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
  11. Toshiba Satellite L305D-S5950 Speaker Replacement, Speaker: step 11, image 1 of 2 Toshiba Satellite L305D-S5950 Speaker Replacement, Speaker: step 11, image 2 of 2
    • Use a phillips head #00 screwdriver to remove the two 5.25mm screws.
  12. Toshiba Satellite L305D-S5950 Speaker Replacement: step 12, image 1 of 2 Toshiba Satellite L305D-S5950 Speaker Replacement: step 12, image 2 of 2
    • Turn the keyboard housing over and disconnect the speaker power wire from the keyboard housing.
    • Remove both speakers.
William
875 Reputation
7 Guides authored
Clemson, Team 1-2, Benson Spring 2014 Member of Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 314
