Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement
  1. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Battery: step 1, image 1 of 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: step 2, image 1 of 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: step 2, image 2 of 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: step 3, image 1 of 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: step 3, image 2 of 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: step 4, image 1 of 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: step 5, image 1 of 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: step 5, image 2 of 2
    • Unscrew the screws enough to remove the top cover.
  6. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: step 6, image 1 of 1
    • Remove the cover by lifting the right side up at an angle before removing the entire cover.
  7. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: step 7, image 1 of 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: step 7, image 2 of 2
    • Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
  8. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: step 8, image 1 of 3 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: step 8, image 2 of 3 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: step 8, image 3 of 3
    • To separate the hard drive from the caddy, unscrew the two screws.
Ricky Baker
217 Reputation
2 Guides authored
Clemson, Team 1-2, Benson Spring 2014 Member of Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 877
