Toshiba Satellite L305D-S5950 CD Drive Replacement
  1. Toshiba Satellite L305D-S5950 CD Drive Replacement, Battery: step 1, image 1 of 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 CD Drive Replacement: step 2, image 1 of 2 Toshiba Satellite L305D-S5950 CD Drive Replacement: step 2, image 2 of 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 CD Drive Replacement: step 3, image 1 of 2 Toshiba Satellite L305D-S5950 CD Drive Replacement: step 3, image 2 of 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 CD Drive Replacement: step 4, image 1 of 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 CD Drive Replacement, CD Drive: step 5, image 1 of 1
    • Locate the RAM cover on the underside of the laptop.
  6. Toshiba Satellite L305D-S5950 CD Drive Replacement: step 6, image 1 of 1
    • Use a phillips head #0 screwdriver to remove the screw located on the RAM cover.
  7. Toshiba Satellite L305D-S5950 CD Drive Replacement: step 7, image 1 of 2 Toshiba Satellite L305D-S5950 CD Drive Replacement: step 7, image 2 of 2
    • Using your fingers, carefully remove the cover.
William
875 Reputation
7 Guides authored
Clemson, Team 1-2, Benson Spring 2014 Member of Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 300
