Toshiba Satellite L305D-S5900 Storage Drive Replacement
  1. Toshiba Satellite L305D-S5900 Storage Drive Replacement, Storage Drive: step 1, image 1 of 1
    • Power off your laptop before beginning disassembly.
    • Two 5.3 mm Phillips #1 screws boxed in red are located at the top right corner on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Storage Drive Replacement: step 2, image 1 of 3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: step 2, image 2 of 3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: step 2, image 3 of 3
    • Remove the panel that houses the storage drive by unscrewing the two 5.3 mm Phillips #1 screws that hold it into place
  3. Toshiba Satellite L305D-S5900 Storage Drive Replacement: step 3, image 1 of 2 Toshiba Satellite L305D-S5900 Storage Drive Replacement: step 3, image 2 of 2
    • The standard hard disk drive that comes with this laptop model should have a ribbon attached to it. Pull this ribbon back until the hard drive comes out of the socket.
    • If your drive doesn’t have this ribbon, it can be pushed out of place by wedging a plastic opening tool in between the drive and its socket and push it out.
Sing Yang Cheng
501 Reputation
5 Guides authored
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 10
All Time: 345
