Toshiba Satellite L305D-S5900 RAM Replacement
  1. Toshiba Satellite L305D-S5900 RAM Replacement, RAM: step 1, image 1 of 1
    • Power off your laptop before beginning dissassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 RAM Replacement: step 2, image 1 of 2 Toshiba Satellite L305D-S5900 RAM Replacement: step 2, image 2 of 2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 RAM Replacement: step 3, image 1 of 3 Toshiba Satellite L305D-S5900 RAM Replacement: step 3, image 2 of 3 Toshiba Satellite L305D-S5900 RAM Replacement: step 3, image 3 of 3
    • There are two metal holdings boxed in red is located at each side of the RAM chip (left and right).
    • Use a plastic opening tool or your fingers to carefully pull or push up from the underside of the RAM chip until it naturally sits in the socket at an angle.
    • If using too much force, push aside the metal holdings that holds on to the RAM chip on both side then attempt lifting it up
    • There are two RAM chips that can be removes. To remove the second RAM chips follow the same instructed as above.
Sing Yang Cheng
501 Reputation
5 Guides authored
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 250
