Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement
  1. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement, Optical Drive (Disk Drive): step 1, image 1 of 1
    • Power off your laptop before beginning disassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: step 2, image 1 of 2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: step 2, image 2 of 2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: step 3, image 1 of 2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: step 3, image 2 of 2
    • The 5.3 mm Phillips #1 screw boxed in red is located on the right panel that house the RAM on the underside of the computer.
    • Remove the screw securing the drive on the plastic edge.
  4. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: step 4, image 1 of 1
    • Use a screwdriver or a metal spludgers to push the metal piece attached to the drive in the direction of the drive opens until the drive pops out of its socket.
  5. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: step 5, image 1 of 1
    • Fully remove the drive by pulling it all the way out of its socket.
Sing Yang Cheng
501 Reputation
5 Guides authored
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 629
