Toshiba Satellite L305-S5955 Keyboard Replacement
  1. Toshiba Satellite L305-S5955 Keyboard Replacement, Lock Tabs: step 1, image 1 of 1
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Keyboard Replacement: step 2, image 1 of 1
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Keyboard Replacement, Keyboard: step 3, image 1 of 1
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Keyboard Replacement: step 4, image 1 of 2 Toshiba Satellite L305-S5955 Keyboard Replacement: step 4, image 2 of 2
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Keyboard Replacement: step 5, image 1 of 1
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Keyboard Replacement: step 6, image 1 of 2 Toshiba Satellite L305-S5955 Keyboard Replacement: step 6, image 2 of 2
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
2 other people completed this guide.
Chris
1 Reputation
1 Guide authored
Ohio State, Team 1-2, Buehl Fall 2014 Member of Ohio State, Team 1-2, Buehl Fall 2014
OSU-BUEHL-F14S1G2
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 922
