Toshiba Satellite L305-S5955 Hard Drive Replacement
  1. Toshiba Satellite L305-S5955 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5955 Hard Drive Replacement: step 2, image 1 of 3 Toshiba Satellite L305-S5955 Hard Drive Replacement: step 2, image 2 of 3 Toshiba Satellite L305-S5955 Hard Drive Replacement: step 2, image 3 of 3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5955 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Locate the hard drive on the laptop, above the part number and serial number sticker
  4. Toshiba Satellite L305-S5955 Hard Drive Replacement: step 4, image 1 of 1
    • Remove the two screws marked "4" from the hard drive cover
  5. Toshiba Satellite L305-S5955 Hard Drive Replacement: step 5, image 1 of 1
    • Pry up the cover of the hard drive compartment.
  6. Toshiba Satellite L305-S5955 Hard Drive Replacement: step 6, image 1 of 2 Toshiba Satellite L305-S5955 Hard Drive Replacement: step 6, image 2 of 2
    • Slide hard drive out by pulling gently on the felt handle
  7. Toshiba Satellite L305-S5955 Hard Drive Replacement: step 7, image 1 of 1
    • Remove four outer black screws on the corners of the hard drive case
  8. Toshiba Satellite L305-S5955 Hard Drive Replacement: step 8, image 1 of 1
    • Remove hard drive from the casing by gently sliding the drive out of the case.
  9. Toshiba Satellite L305-S5955 Hard Drive Replacement: step 9, image 1 of 1
    • Complete these steps in reverse order to insert hard drive back into laptop.
2 other people completed this guide.
Eric
55 Reputation
1 Guide authored
Ohio State, Team 1-2, Buehl Fall 2014 Member of Ohio State, Team 1-2, Buehl Fall 2014
OSU-BUEHL-F14S1G2
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 28
All Time: 970
