Toshiba Satellite L305-S5946 Power Jack Replacement
  1. Toshiba Satellite L305-S5946 Power Jack Replacement, Battery: step 1, image 1 of 1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 Power Jack Replacement: step 2, image 1 of 1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 Power Jack Replacement: step 3, image 1 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 3, image 2 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 3, image 3 of 3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 Power Jack Replacement, Hard Drive: step 4, image 1 of 1
    • Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
  5. Toshiba Satellite L305-S5946 Power Jack Replacement: step 5, image 1 of 2 Toshiba Satellite L305-S5946 Power Jack Replacement: step 5, image 2 of 2
    • Lift the hard drive cover using a non-marring iFixit opening tool.
    • This will expose the hard drive.
  6. Toshiba Satellite L305-S5946 Power Jack Replacement: step 6, image 1 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 6, image 2 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 6, image 3 of 3
    • Slide the hard drive to the left using your fingers.
    • Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
  7. Toshiba Satellite L305-S5946 Power Jack Replacement, RAM: step 7, image 1 of 1
    • Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
    • This is a captive panel screw and remains with the cover.
  8. Toshiba Satellite L305-S5946 Power Jack Replacement: step 8, image 1 of 2 Toshiba Satellite L305-S5946 Power Jack Replacement: step 8, image 2 of 2
    • Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
  9. Toshiba Satellite L305-S5946 Power Jack Replacement: step 9, image 1 of 2 Toshiba Satellite L305-S5946 Power Jack Replacement: step 9, image 2 of 2
    • Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
    • The RAM card should pop up at an angle.
  10. Toshiba Satellite L305-S5946 Power Jack Replacement: step 10, image 1 of 2 Toshiba Satellite L305-S5946 Power Jack Replacement: step 10, image 2 of 2
    • Pull the RAM card away from the computer.
    • Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
  11. Toshiba Satellite L305-S5946 Power Jack Replacement, Keyboard: step 11, image 1 of 1
    • Place the laptop right-side-up so the screen faces you.
  12. Toshiba Satellite L305-S5946 Power Jack Replacement: step 12, image 1 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 12, image 2 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 12, image 3 of 3
    • Remove the strip of plastic at the right furthermost edge of the keyboard using a plastic opening tool.
    • Insert the plastic opening tool at either end of the strip.
    • Lift upwards and proceed to the other end while repeating this lifting process every one to two inches.
  13. Toshiba Satellite L305-S5946 Power Jack Replacement: step 13, image 1 of 1
    • CAUTION: do not allow hardware or debris into the CPU fan and duct.
    • Remove the two 3-mm screws at the top edge of the keyboard using a Phillips #00 screwdriver.
    • These are not captive panel screws and, once loosened, will be free to move about the assembly.
  14. Toshiba Satellite L305-S5946 Power Jack Replacement: step 14, image 1 of 2 Toshiba Satellite L305-S5946 Power Jack Replacement: step 14, image 2 of 2
    • Pry the top of the keyboard loose from its casing using a plastic opening tool.
  15. Toshiba Satellite L305-S5946 Power Jack Replacement: step 15, image 1 of 1
    • Gently grasp the top of the keyboard and pull it up and toward the screen.
    • CAUTION: Pulling too hard could damage the black ribbon cable under the keyboard.
  16. Toshiba Satellite L305-S5946 Power Jack Replacement: step 16, image 1 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 16, image 2 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 16, image 3 of 3
    • Gently push the two tabs locking the black ribbon cable.
    • To remove the black ribbon cable from the motherboard, slide the keyboard toward the screen.
    • You may now safely separate the keyboard from the laptop.
  17. Toshiba Satellite L305-S5946 Power Jack Replacement, Base Housing: step 17, image 1 of 1
  18. Toshiba Satellite L305-S5946 Power Jack Replacement: step 18, image 1 of 1
    • For the following steps, use a Phillips #1 screwdriver.
    • Remove the twelve 6-mm screws that border the bottom of the laptop.
    • Remove the 6-mm screw located in the lower middle of the device.
    • Remove the three 3-mm screws located in the battery bay.
    • Remove the one 4-mm screw located near the RAM.
  19. Toshiba Satellite L305-S5946 Power Jack Replacement: step 19, image 1 of 1
  20. Toshiba Satellite L305-S5946 Power Jack Replacement: step 20, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the five 6-mm screws in the keyboard slot.
  21. Toshiba Satellite L305-S5946 Power Jack Replacement: step 21, image 1 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 21, image 2 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 21, image 3 of 3
    Tool used on this step:
    Buy
    • Lock the white ribbon cable into place by gently pulling on the two black tabs.
    • Remove the white ribbon cable by pulling it towards you.
    • Remove the connector that has the blue, red, black, and white wires using tweezers.
  22. Toshiba Satellite L305-S5946 Power Jack Replacement: step 22, image 1 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 22, image 2 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 22, image 3 of 3
    • Separate the laptop upper casing from the lower casing by using an opening tool around the sides of the case to pry it apart.
  23. Toshiba Satellite L305-S5946 Power Jack Replacement, Power Jack: step 23, image 1 of 1
    • Flip over your laptop so that it is right-side up.
    • Open your laptop so that the screen faces you.
  24. Toshiba Satellite L305-S5946 Power Jack Replacement: step 24, image 1 of 2 Toshiba Satellite L305-S5946 Power Jack Replacement: step 24, image 2 of 2
    • Using your fingers, gently slide the DVD drive out through the opening on the right side.
  25. Toshiba Satellite L305-S5946 Power Jack Replacement: step 25, image 1 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 25, image 2 of 3 Toshiba Satellite L305-S5946 Power Jack Replacement: step 25, image 3 of 3
    • Using your fingers, gently slide the heading with two black wires and two red wires out of its receptacle. Gently slide the power jack up.
9 other people completed this guide.
Michael Erberich
130 Reputation
9 Guides authored
Cal Poly, Team 3-49, Amido Spring 2013 Member of Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
4 Members
19 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 32
All Time: 7,830
