Introduction
Use this guide to replace the cooling fan in your Toshiba Satellite L305-S5946 if you notice your current part is not functioning properly, which may be indicated by the computer shutting down unexpectedly.
Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
Place the laptop upside-down with the display hinges facing away from you.
For the following steps, use a Phillips #1 screwdriver.
Remove the twelve 6-mm screws that border the bottom of the laptop.
Remove the 6-mm screw located in the lower middle of the device.
Remove the three 3-mm screws located in the battery bay.
Remove the one 4-mm screw located near the RAM.
Remove the four 6-mm screws from the two hinge pads using a Phillips #1 screwdriver.
Tool used on this step:Tweezers$4.99
For the following steps, use tweezers:
Remove the connector equipped with the black and white wire.
Remove the connector equipped with the black, green, red, yellow, and white wires.
Using your fingers, remove the large connector located at the top right corner of the motherboard, as shown.
Remove the power jack connector.
Remove the connector equipped with one red wire and one black wire.
Remove the connector equipped with red, yellow, green, white, and black wires.
Remove the large connector near the fan.
Remove the power jack cable and socket from its housing by pulling gently.
Flip the motherboard over. Remove the two 3-mm screws from the fan using a Phillips #1 screwdriver.
3 other people completed this guide.
