Toshiba Satellite L15W-B1303 USB Port Replacement
  1. Toshiba Satellite L15W-B1303 USB Port Replacement, Bottom Panel: step 1, image 1 of 3 Toshiba Satellite L15W-B1303 USB Port Replacement, Bottom Panel: step 1, image 2 of 3 Toshiba Satellite L15W-B1303 USB Port Replacement, Bottom Panel: step 1, image 3 of 3
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba Satellite L15W-B1303 USB Port Replacement, USB Port: step 2, image 1 of 1
    • Disconnect the cable that connects the receiver to the laptop using the pointed end of a spudger.
  3. Toshiba Satellite L15W-B1303 USB Port Replacement: step 3, image 1 of 1
    • Remove the single JIS #00 screw.
  4. Toshiba Satellite L15W-B1303 USB Port Replacement: step 4, image 1 of 2 Toshiba Satellite L15W-B1303 USB Port Replacement: step 4, image 2 of 2
    • Peel back the material covering this wire.
    • Gently pull the board out carefully to avoid damaging the connector.
Justin Caruso
147 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 557
