Toshiba Satellite L15W-B1303 Charging Port Replacement
  1. Toshiba Satellite L15W-B1303 Charging Port Replacement, Bottom Panel: step 1, image 1 of 3 Toshiba Satellite L15W-B1303 Charging Port Replacement, Bottom Panel: step 1, image 2 of 3 Toshiba Satellite L15W-B1303 Charging Port Replacement, Bottom Panel: step 1, image 3 of 3
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba Satellite L15W-B1303 Charging Port Replacement, Charging Port: step 2, image 1 of 1
    • Detach the white connector from the laptop using the pointed end of a spudger.
  3. Toshiba Satellite L15W-B1303 Charging Port Replacement: step 3, image 1 of 1
    • Once the port has been disconnected, carefully lift the whole charging port off the panel.
Alejandro Oliveros
85 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 192
