Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement
  1. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, Battery: step 1, image 2 of 2
    • Power off your laptop before continuing.
    • Remove the following two 4mm screws with a Phillips #0 screwdriver.
  2. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: step 2, image 1 of 1
    • Slide the battery out towards you.
  3. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, Bottom Case: step 3, image 1 of 1
    • Remove the following twelve 4mm screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: step 4, image 1 of 1
    • Use a spudger to depress the six white clips connecting the plastic cover
  5. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: step 5, image 1 of 1
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
  6. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: step 6, image 1 of 1
    • Remove the cover and set to the side.
  7. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, USB HDMI Audio Circuit Board: step 7, image 1 of 3 Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, USB HDMI Audio Circuit Board: step 7, image 2 of 3 Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, USB HDMI Audio Circuit Board: step 7, image 3 of 3
    • Use the point end of the spudger to lift the clips that attach the two ribbons to the motherboard.
    • Pull out the ribbons from the motherboard.
  8. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: step 8, image 1 of 2 Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: step 8, image 2 of 2
    • Unscrew the 2mm screw with a Phillips #0 screwdriver.
    • Remove the circuit board.
Joshua Swanson
701 Reputation
6 Guides authored
USF Tampa, Team S2-G2, Sullivan Spring 2017 Member of USF Tampa, Team S2-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G2
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 10
All Time: 305
