Toshiba Satellite E45t-B4204 Thermal Paste Replacement
  1. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: step 1, image 1 of 3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: step 1, image 2 of 3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: step 1, image 3 of 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: step 2, image 1 of 2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: step 2, image 2 of 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: step 3, image 1 of 3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: step 3, image 2 of 3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: step 3, image 3 of 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: step 4, image 1 of 2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: step 4, image 2 of 2
    • Locate and remove the four 3 mm screws around the CPU.
    • The CPU is located beneath the copper heatsink.
  5. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: step 5, image 1 of 2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: step 5, image 2 of 2
    • Carefully remove the heatsink from the rest of the motherboard and casing.
  6. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: step 6, image 1 of 2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: step 6, image 2 of 2
    • Now that the heatsink has been removed the CPU is visible. The CPU is the green square with silver metal in the center.
    • Reapply thermal paste above the CPU.
Eduardo
411 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 455
