Toshiba Satellite E45t-B4204 Speaker Replacement
  1. Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: step 1, image 1 of 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: step 1, image 2 of 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: step 1, image 3 of 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Speaker Replacement: step 2, image 1 of 2 Toshiba Satellite E45t-B4204 Speaker Replacement: step 2, image 2 of 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Speaker Replacement: step 3, image 1 of 3 Toshiba Satellite E45t-B4204 Speaker Replacement: step 3, image 2 of 3 Toshiba Satellite E45t-B4204 Speaker Replacement: step 3, image 3 of 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: step 4, image 1 of 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: step 4, image 2 of 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: step 4, image 3 of 3
    • Unscrew the 4 screws at the sides of each speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Speaker Replacement: step 5, image 1 of 1
    • Disconnect the speaker cable from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo has the potential to damage your device.
  6. Toshiba Satellite E45t-B4204 Speaker Replacement: step 6, image 1 of 1
    • Remove the speakers.
Emily Bateman
97 Reputation
1 Guide authored
IUPUI, Team S3-G3, Wilson Summer 2019 Member of IUPUI, Team S3-G3, Wilson Summer 2019
IUPUI-WILSON-SU19S3G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 19
All Time: 571
