Toshiba Satellite E45t-B4204 Keyboard Replacement
  1. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: step 1, image 1 of 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: step 1, image 2 of 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: step 1, image 3 of 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 2, image 1 of 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 2, image 2 of 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 3, image 1 of 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 3, image 2 of 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 3, image 3 of 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: step 4, image 1 of 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: step 4, image 2 of 2
    • Remove speaker by unscrewing the 4 screws at the side of the speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 5, image 1 of 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 5, image 2 of 2
    • Unplug speaker wires from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo could potentially damage your device.
    • Remove speakers.
  6. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 6, image 1 of 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 6, image 2 of 2
    • Unscrew 6 screws from the chassis with the Phillips #1 screwdriver.
  7. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 7, image 1 of 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 7, image 2 of 2
    • Unscrew 8 screws from the motherboard using the Phillips #1 screwdriver.
  8. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 8, image 1 of 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 8, image 2 of 2
    • Unplug wire from the motherboard.
  9. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 9, image 1 of 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 9, image 2 of 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 9, image 3 of 3
    • Unscrew screws from the motherboard using the Phillips #1 screwdriver.
  10. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 10, image 1 of 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 10, image 2 of 2
    • Unscrew screws from the CPU heat sink using the Phillips #1 screwdriver.
  11. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 11, image 1 of 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 11, image 2 of 2
    • Unplug the wire from the motherboard.
    • Remove the heat sink.
  12. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 12, image 1 of 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 12, image 2 of 2
    • Remove the CPU.
  13. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 13, image 1 of 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 13, image 2 of 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 13, image 3 of 3
    • Unscrew the motherboard with the Phillips #1 screwdriver.
  14. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 14, image 1 of 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 14, image 2 of 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 14, image 3 of 3
    • Remove the motherboard.
  15. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 15, image 1 of 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 15, image 2 of 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 15, image 3 of 3
    • Unscrew the keyboard cover using the Phillips #0 screwdriver.
    • Unscrew the keyboard cover using the #1 screwdriver.
  16. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 16, image 1 of 1
    • Remove the keyboard cover.
  17. Toshiba Satellite E45t-B4204 Keyboard  Replacement: step 17, image 1 of 1
    • Remove the keyboard.
Youdong Yan
229 Reputation
1 Guide authored
IUPUI, Team S3-G3, Wilson Summer 2019 Member of IUPUI, Team S3-G3, Wilson Summer 2019
IUPUI-WILSON-SU19S3G3
4 Members
6 Guides authored
One Comment
Do you know where in this process the webcam is connected/disconnected? I just completed this process to replace the keyboard and swap in a new SSD while I had everything opened up. I got everything closed back up, and it's all running great, but just noticed that the computer no longer recognizes that there is a webcam. I would swear I plugged in everything that I had unplugged, but I can't figure out where the webcam connection might be.
Brent Murphy - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 14
All Time: 548
