Toshiba Satellite E45t-B4204 Fan Replacement
  1. Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: step 1, image 1 of 3 Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: step 1, image 2 of 3 Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: step 1, image 3 of 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Fan Replacement: step 2, image 1 of 2 Toshiba Satellite E45t-B4204 Fan Replacement: step 2, image 2 of 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Fan Replacement: step 3, image 1 of 3 Toshiba Satellite E45t-B4204 Fan Replacement: step 3, image 2 of 3 Toshiba Satellite E45t-B4204 Fan Replacement: step 3, image 3 of 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Fan Replacement, Fan: step 4, image 1 of 1
    • Locate the fan.
    • The fan is a grey plastic with a black circular fan in the center.
  5. Toshiba Satellite E45t-B4204 Fan Replacement: step 5, image 1 of 3 Toshiba Satellite E45t-B4204 Fan Replacement: step 5, image 2 of 3 Toshiba Satellite E45t-B4204 Fan Replacement: step 5, image 3 of 3
    • Remove all 4 mm screws with a Phillips #1 screwdriver.
  6. Toshiba Satellite E45t-B4204 Fan Replacement: step 6, image 1 of 2 Toshiba Satellite E45t-B4204 Fan Replacement: step 6, image 2 of 2
    • Locate the red, black, and yellow wire connecting to the motherboard.
  7. Toshiba Satellite E45t-B4204 Fan Replacement: step 7, image 1 of 3 Toshiba Satellite E45t-B4204 Fan Replacement: step 7, image 2 of 3 Toshiba Satellite E45t-B4204 Fan Replacement: step 7, image 3 of 3
    • Unplug the wire from the motherboard. Once it is unplugged you will remove the fan.
Perla Ruiz
159 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 259
