Toshiba Satellite E45T-A4300 Hard Drive Replacement
  1. Toshiba Satellite E45T-A4300 Hard Drive Replacement, Back Panel: step 1, image 1 of 1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 Hard Drive Replacement: step 2, image 1 of 1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Remove the three 7mm black screws using the Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300 Hard Drive Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the hard drive’s connection port with grooved tweezers.
  5. Toshiba Satellite E45T-A4300 Hard Drive Replacement: step 5, image 1 of 2 Toshiba Satellite E45T-A4300 Hard Drive Replacement: step 5, image 2 of 2
    • Pull the hard drive out of the hook and remove it from the device.
James Nguyen
573 Reputation
5 Guides authored
One Comment
Can I replace it with some regular 256GB SSD?
Dheeraj Sah - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 891
