Toshiba Satellite E105-S1602 Keyboard Replacement
  1. Toshiba Satellite E105-S1602 Keyboard Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite E105-S1602 Keyboard Replacement, Battery: step 1, image 2 of 2
    • Slide both of the latches to the outside to release the battery.
  2. Toshiba Satellite E105-S1602 Keyboard Replacement: step 2, image 1 of 2 Toshiba Satellite E105-S1602 Keyboard Replacement: step 2, image 2 of 2
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: step 3, image 1 of 3 Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: step 3, image 2 of 3 Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: step 3, image 3 of 3
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Toshiba Satellite E105-S1602 Keyboard Replacement: step 4, image 1 of 2 Toshiba Satellite E105-S1602 Keyboard Replacement: step 4, image 2 of 2
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. Toshiba Satellite E105-S1602 Keyboard Replacement: step 5, image 1 of 2 Toshiba Satellite E105-S1602 Keyboard Replacement: step 5, image 2 of 2
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Toshiba Satellite E105-S1602 Keyboard Replacement: step 6, image 1 of 1
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Toshiba Satellite E105-S1602 Keyboard Replacement: step 7, image 1 of 1
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Toshiba Satellite E105-S1602 Keyboard Replacement: step 8, image 1 of 2 Toshiba Satellite E105-S1602 Keyboard Replacement: step 8, image 2 of 2
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
Ian Washburne
59 Reputation
6 Guides authored
Cal Poly, Team 17-21, Forte Winter 2013 Member of Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 1,571
