Toshiba Satellite C875-S7304 Battery Replacement
  1. Toshiba Satellite C875-S7304 Battery Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite C875-S7304 Battery Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite C875-S7304 Battery Replacement, Battery: step 1, image 3 of 3
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Battery Replacement: step 2, image 1 of 2 Toshiba Satellite C875-S7304 Battery Replacement: step 2, image 2 of 2
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Battery Replacement: step 3, image 1 of 1
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Battery Replacement: step 4, image 1 of 1
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Battery Replacement: step 5, image 1 of 1
    • Lift the battery out carefully using two hands.
Emma King
334 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 20
All Time: 641
