Toshiba Satellite C855D-S5303 RAM Replacement
  1. Toshiba Satellite C855D-S5303 RAM Replacement, RAM: step 1, image 1 of 3 Toshiba Satellite C855D-S5303 RAM Replacement, RAM: step 1, image 2 of 3 Toshiba Satellite C855D-S5303 RAM Replacement, RAM: step 1, image 3 of 3
    • Using a small Phillip's head screwdriver, unscrew the single 7 mm screw (5 mm head) on the L-shaped panel on the backside of the laptop.
    • Once the screw is removed, pry the panel upwards by gripping the groove pictured.
    • Be gentle while lifting the panel. You do not want to break it by applying too much force.
  2. Toshiba Satellite C855D-S5303 RAM Replacement: step 2, image 1 of 3 Toshiba Satellite C855D-S5303 RAM Replacement: step 2, image 2 of 3 Toshiba Satellite C855D-S5303 RAM Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Using the curved tweezers from the Precision Tweezers Set grab and pull the metal clips away from each side of the RAM.
  3. Toshiba Satellite C855D-S5303 RAM Replacement: step 3, image 1 of 2 Toshiba Satellite C855D-S5303 RAM Replacement: step 3, image 2 of 2
    • Now the card is free to remove; pull out and up from the slot that it is in.
Courtney Burns
836 Reputation
5 Guides authored
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 15
All Time: 632
