Toshiba Satellite C855D-S5303 Hard Drive Replacement
  1. Toshiba Satellite C855D-S5303 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Using a small Phillip's head screwdriver, unscrew the single 7 mm screw (5 mm head) on the L-shaped panel on the backside of the laptop.
  2. Toshiba Satellite C855D-S5303 Hard Drive Replacement: step 2, image 1 of 2 Toshiba Satellite C855D-S5303 Hard Drive Replacement: step 2, image 2 of 2
    • Once the screw is removed, pry the panel upwards by gripping the groove pictured.
    • Be careful while removing the panel. Don't apply too much force when lifting as you may crack the plastic.
  3. Toshiba Satellite C855D-S5303 Hard Drive Replacement: step 3, image 1 of 3 Toshiba Satellite C855D-S5303 Hard Drive Replacement: step 3, image 2 of 3 Toshiba Satellite C855D-S5303 Hard Drive Replacement: step 3, image 3 of 3
    • Locate the hard drive. It is in a metal casing as pictured.
    • To remove, grab the right side of the piece and slide leftwards.
    • Lift up and out.
4 other people completed this guide.
Courtney Burns
836 Reputation
5 Guides authored
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 17
All Time: 1,648
