Toshiba Satellite C855D-S5303 Disc Drive Replacement
  1. Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: step 1, image 1 of 3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: step 1, image 2 of 3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: step 1, image 3 of 3
    • To begin, locate the middle L-shaped panel on the back of the device. Remove the one 7mm long screw (5mm head) located on that panel.
    • Once the screw is removed, lift the panel by grabbing the indentation by the screw and pulling upwards.
    • Be gentle when lifting, the panel could break if you apply too much force.
  2. Toshiba Satellite C855D-S5303 Disc Drive Replacement: step 2, image 1 of 1
    • Locate the screw to the right of the RAM inside the panel. This screw is 6mm long (5mm head); remove it with a small Phillips head screwdriver.
  3. Toshiba Satellite C855D-S5303 Disc Drive Replacement: step 3, image 1 of 2 Toshiba Satellite C855D-S5303 Disc Drive Replacement: step 3, image 2 of 2
    • Now that the single screw is removed, you should be able to smoothly slide out the disc drive.
    • Do this by grabbing the tray located on the right edge of your device and pulling out.
Courtney Burns
836 Reputation
5 Guides authored
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 357
