Toshiba Satellite C855D-S5109 RAM Replacement
  1. Toshiba Satellite C855D-S5109 RAM Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite C855D-S5109 RAM Replacement, Battery: step 1, image 2 of 2
    • Flip the laptop over so the bottom is facing up.
  2. Toshiba Satellite C855D-S5109 RAM Replacement: step 2, image 1 of 2 Toshiba Satellite C855D-S5109 RAM Replacement: step 2, image 2 of 2
    • Slide the two lock tabs on the battery to the open position.
  3. Toshiba Satellite C855D-S5109 RAM Replacement: step 3, image 1 of 3 Toshiba Satellite C855D-S5109 RAM Replacement: step 3, image 2 of 3 Toshiba Satellite C855D-S5109 RAM Replacement: step 3, image 3 of 3
    • While still holding the lock tabs outward, use your hand to grab the top of battery and pull up.
    • Remove the battery.
  4. Toshiba Satellite C855D-S5109 RAM Replacement, RAM: step 4, image 1 of 1
    • Flip the laptop around so that the bottom is facing you.
  5. Toshiba Satellite C855D-S5109 RAM Replacement: step 5, image 1 of 1
    • Unscrew the Phillips #00 screw, and remove the back cover.
  6. Toshiba Satellite C855D-S5109 RAM Replacement: step 6, image 1 of 1
    • Spread the metal clamps on either side of the RAM card outward so the RAM pops up.
  7. Toshiba Satellite C855D-S5109 RAM Replacement: step 7, image 1 of 1
    • Pull the RAM out of the slot in a horizontal direction.
    • Be sure to only handle the edges of the RAM card, as the oils on your fingers can cause damage if they make contact with the face of the card.
Kaia Herrera
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 163
